Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown. While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
  • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
  • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
  • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
  • Remove the last remaining T8 Torx screw securing the display to the upper case.
Insérez ici votre traduction
