Aller au contenu principal
Google Pixel 4 XL Charging Assembly Replacement
Anglais
Français
Traduction de l’étape 2
Étape 2
Google Pixel 4 XL Charging Assembly Replacement: étape 0, image 1 de 2 Google Pixel 4 XL Charging Assembly Replacement: étape 0, image 2 de 2
  • Use a pair of tweezers to remove the loudspeaker.
  • Before you install a replacement loudspeaker, check the adhesive gasket:
  • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
  • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
Insérez ici votre traduction
