Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 3 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
During reassembly, check the clicking action on the trackpad.
  • During reassembly, check the clicking action on the trackpad.
  • The 1.4 mm T5 Torx screw near the front edge of the case must be adjusted correctly.
  • If overtightened, the button will cease to click at a certain point. Adjust the set screw until the clicking side of the trackpad has minimal play.
  • It's not necessary to remove this screw in order to remove the trackpad.
Retirez la vis T5 Torx de 1,4 mm de son trou près du bord avant du boîtier supérieur.
Lors du remontage, ne serrez pas trop la vis de réglage, car le bouton finit par arrêter de cliquer. Ajustez la vis de réglage jusqu'à ce que le côté de clic du pavé tactile ait un jeu minimal.
-[* red] Remove the 1.4 mm T5 Torx set screw from its tapped hole near the front edge of the upper case.
-[* icon_reminder] During reassembly, do not over-tighten the set screw, as the button will cease to click at a certain point. Adjust the set screw until the clicking side of the trackpad has minimal play.
+[* icon_reminder] During reassembly, check the clicking action on the trackpad.
+ [* red] The 1.4 mm T5 Torx screw near the front edge of the case must be adjusted correctly.
+ [* icon_note] If overtightened, the button will cease to click at a certain point. Adjust the set screw until the clicking side of the trackpad has minimal play.
+[* icon_note] It's not necessary to remove this screw in order to remove the trackpad.
