Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
What's worse than removing a glued-down Note battery? Removing two of them ... at the same time. Luckily we've got our adhesive remover handy. A few squirts, some patience, and a little persuasion from a pair of suction cups helps us safely remove both batteries without breaking too much of a sweat. By this point, it feels inevitable that Samsung batteries will always be glued in like this, but we're not ready to give up hope yet. Samsung, if you're listening, there's a better way. (And prior to that, there was an even better-er way.)
  • What's worse than removing a glued-down Note battery? Removing two of them ... at the same time.
  • Luckily we've got our adhesive remover handy. A few squirts, some patience, and a little persuasion from a pair of suction cups helps us safely remove both batteries without breaking too much of a sweat.
  • By this point, it feels inevitable that Samsung batteries will always be glued in like this, but we're not ready to give up hope yet. Samsung, if you're listening, there's a better way. (And prior to that, there was an even better-er way.)
  • These Note 20 and Note 20 Ultra juice packs weigh in at 16.69 and 17.46 watt-hours, respectively.
  • Both beat the 15.04 Wh pack in the iPhone 11 Pro Max, but fall behind the 19.30 Wh monster in the S20 Ultra—which didn't have to make room for a stylus, therefore moar battery.
Qu'est-ce qui est pire que de décoller une batterie de Note ? En décoller deux… en même temps.
Par chance, nous avons notre dissolvant pour adhésif sous la main. Quelques giclées, un peu de patience et une paire de ventouses tenaces nous aident à retirer les deux batteries en toute sécurité et sans trop transpirer.
On dirait bien que les dés sont jetés et que les batteries Samsung seront toujours collées à l'avenir, mais nous n'abandonnons pas encore tout espoir. Samsung, au cas où vous nous écoutiez, il y a meilleur moyen. (Et il y même déjà eu encore meilleur moyen.)
Les cellules du Note 20 et du Note 20 Ultra cartonnent respectivement à 16,69 et 17,46 watts-heures.
Elles battent toutes deux les 15,04 Wh de l'iPhone 11 Pro Max, mais sont bien loin du monstre de 19,30 Wh du S20 Ultra. Ce dernier n'avait pas besoin de place pour un stylet, donc bien plus d'espace libre pour la batterie.
