Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 7
Étape 7
Use the pointed end of a spudger and pry up gently to unclip the bottom antenna connector from the motherboard. You can also use a pair of tweezers to grip the metal clip and pull the connector straight up off of the motherboard.
Disconnect the antennas
  • Use the pointed end of a spudger and pry up gently to unclip the bottom antenna connector from the motherboard.
  • You can also use a pair of tweezers to grip the metal clip and pull the connector straight up off of the motherboard.
Insérez ici votre traduction
