Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 14 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 15
Étape 15
Whenever you use the spudger near the battery, be very careful not to puncture the battery. Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
  • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
  • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
  • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
Insérez ici votre traduction
