Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Pull on the yellow pull tab at a shallow angle with steady force. If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling. Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
  • Pull on the yellow pull tab at a shallow angle with steady force.
  • If the adhesive becomes hard to pull, you can roll it around a spudger and continue pulling.
  • Continue firmly pulling up on the adhesive strip with constant force. If you're using a spudger, spin it every so often to keep the exposed section of the pull tab as short as possible.
  • This may take a lot of force.
  • These adhesive pull tabs are very prone to snapping in half during this process. Pull as slowly as possible.
  • If the adhesive pull tabs are not stretching, you can fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops under the left edge of the battery. Give the alcohol a minute to weaken the battery adhesive.
  • Continue this process for each of the three pull tabs, until all are either out or have snapped in half.
Insérez ici votre traduction
