Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 4
Étape 4
Use a pair of tweezers to slide the loudspeaker towards the top of the phone to clear the retention clip. Remove the loudspeaker. Before you install a replacement loudspeaker, check the adhesive gasket:
  • Use a pair of tweezers to slide the loudspeaker towards the top of the phone to clear the retention clip.
  • Remove the loudspeaker.
  • Before you install a replacement loudspeaker, check the adhesive gasket:
  • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the exit hole.
  • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
Insérez ici votre traduction
