Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Use a pair of tweezers to remove the microphone. Before you install a replacement microphone, check the adhesive gasket:
  • Use a pair of tweezers to remove the microphone.
  • Before you install a replacement microphone, check the adhesive gasket:
  • If it is in good condition, you can re-use the gasket. Make sure that the gasket does not cover the hole.
  • If the gasket is pulled out of place, remove it and replace the adhesive with a pre-cut strip or Tesa tape.
Insérez ici votre traduction
