Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 14 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 10
Étape 10
Slide the pick all along the right edge of the phone to separate the back cover's adhesive. Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing. As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
  • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
  • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
Faites glisser le médiator vers le bord inférieur du téléphone pour trancher l'adhésif.
Laissez votre médiator sous le bord inférieur droit de la vitre afin qu'elle ne recolle plus.
Il est possible que la coque laisse tomber un ou deux des autres médiators. Si c'est le cas, mettez-le(s) de côté, car il est peu probable que le bord inférieur recolle à présent.
