Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 5
Étape 5
The back part of the phone is attatched to the board and lcd by 8 clips on each side (pic 1 ilustrates the biggest one) and two clips on the top (pic 3) Removing it consists in pulling from the sides on the phone (from the point shown in pic 1) and pushing from the battery slot onto the motherboard Careful when pushing on the motherboard, as the top part of the phone is securely held by a plastic piece that doesn't let go easily. Just pull the board out from the 8 clips and, when done, slowly let the motherboard down on the case (picture 2), hold it by the sides of the display and gently try to make the top part let go (shown in picture 3).
  • The back part of the phone is attatched to the board and lcd by 8 clips on each side (pic 1 ilustrates the biggest one) and two clips on the top (pic 3)
  • Removing it consists in pulling from the sides on the phone (from the point shown in pic 1) and pushing from the battery slot onto the motherboard
  • Careful when pushing on the motherboard, as the top part of the phone is securely held by a plastic piece that doesn't let go easily. Just pull the board out from the 8 clips and, when done, slowly let the motherboard down on the case (picture 2), hold it by the sides of the display and gently try to make the top part let go (shown in picture 3).
La partie arrière du téléphone est attachée à la carte et lcd par 8 clips de chaque côté (l'image 1 illustre le plus grand) et deux clips sur le dessus (photo 3)
Le retirer consiste à tirer sur les côtés du téléphone (à partir du point indiqué sur la photo 1) et à pousser de la fente de la batterie sur la carte mère
Lorsque vous appuyez sur la carte mère, car la partie supérieure du téléphone est maintenue par une pièce en plastique qui ne laisse pas enlever facilement. Retirez la carte des 8 clips et, une fois terminé, laissez la carte sur le boîtier (image 2), tenez-la par les côtés de l'écran et essayez de faire lâcher la partie supérieure (voir image 3) ).
