Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure. If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
Remove the old adhesive
  • Before you install new adhesive strips, remove all of the old adhesive from the perimeter of the rear enclosure.
  • If you are re-using your existing display, you must also remove the old adhesive from the back of the display.
  • Peel off the old strips of adhesive using tweezers or your fingers. Start at the bottom and peel upward towards the top of the device.
  • After all the old adhesive is removed, carefully clean off the adhesive residue with high-concentration isopropyl alcohol (90% or greater) and a lint-free cloth. Wipe in one direction, not back and forth.
  • Don't skip this step, or your new adhesive strips may not bond properly, and the display may fall out of your iMac.
Insérez ici votre traduction
