Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
Once you've aligned the bottom half of the adhesive strip, peel the longer piece of backing out from behind the strip. If the bottom half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
  • Once you've aligned the bottom half of the adhesive strip, peel the longer piece of backing out from behind the strip.
  • If the bottom half isn't aligned properly, you can carefully peel it up and re-stick it before peeling off the lower backing strip. Be sure to use the spudger tip to anchor the top.
Insérez ici votre traduction
