Aller au contenu principal
Anglais
Français
Traduction de l’étape 19
Étape 19
At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips. If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 22.
Test the display
  • At this point it's a good idea to test your repair, in order to make sure your iMac works properly before you seal it back up. Follow the next three steps to temporarily reconnect the display cables and boot up your iMac prior to pulling the protective film off the adhesive strips.
  • If you've already verified that your iMac is working correctly and are ready to seal it up, skip to step 22.
  • Insert the display power cable into its socket on the logic board.
Insérez ici votre traduction
