Aller au contenu principal
Anglais
Français
Traduction de l’étape 22
Étape 22
Verify that your iMac is turned off and unplugged from power before you continue. After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward. Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
Seal the iMac
  • Verify that your iMac is turned off and unplugged from power before you continue.
  • After confirming that your iMac functions properly, disconnect the display cables and carefully lean the display forward.
  • Remove the film from the two bottom strips by reaching in from above with a pair of tweezers and pulling the blue tabs straight up from the bottom edge of the display.
Insérez ici votre traduction
