Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 6
Étape 6
Almost there! Time to really go wireless by disconnecting the three WiFi and bluetooth antennas. These are tiny snaps so pull gently upward. Also, sneaking in from underneath, you'll find the iSight camera cable. Unplug it. This is one to look out for when you reinstall the logic board. At last you'll disconnect the main power cord and the Hard Drive SATA cable. I photographed the top one already disconnected; be sure to squeeze the edge tabs to release the clamp hooks. The HDD SATA connector has a convenient pull tab. At last you'll disconnect the main power cord and the Hard Drive SATA cable. I photographed the top one already disconnected; be sure to squeeze the edge tabs to release the clamp hooks. The HDD SATA connector has a convenient pull tab.
  • Almost there! Time to really go wireless by disconnecting the three WiFi and bluetooth antennas. These are tiny snaps so pull gently upward. Also, sneaking in from underneath, you'll find the iSight camera cable. Unplug it. This is one to look out for when you reinstall the logic board.
  • At last you'll disconnect the main power cord and the Hard Drive SATA cable. I photographed the top one already disconnected; be sure to squeeze the edge tabs to release the clamp hooks. The HDD SATA connector has a convenient pull tab.
Nous avons presque fini ! Il est temps de vraiment passer en mode sans-fils en déconnectant les trois antennes Wi-Fi et Bluetooth. Ce sont des petites prises donc allez-y doucement en les tirants vers le haut. Vous pourrez aussi trouver le câble iSight caché dessous. Débranchez-le. N'oubliez pas de le rebrancher au remontage de la carte mère.
Pour finir, débranchez le câble d'alimentation principale et le câble SATA du HDD. La photo montre le câble supérieur deja déconnecté, faites attention a bien pincer les coins de la prise pour débloquer le cable. Le câble HDD SATA a une languette pour faciliter son retrait.
