Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
The 5mm screw is located below the button. You need to loose it. (Loose but do not loose.) If you unscrew both. You can try to blow compressed air through the holes. This can already solve the problem.
Hexen
  • The 5mm screw is located below the button. You need to loose it. (Loose but do not loose.)
  • If you unscrew both. You can try to blow compressed air through the holes. This can already solve the problem.
  • This screw holds the break/button part on the wheel. Later you will need to pull it off. As you can see the cable goes through the rubber grips.
Insérez ici votre traduction
