Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
If you are unlucky and loose the cable inside. Try to fix it to a wire. You can also try to use the wire, to block the path through that hole in the wheel, and push just the cable. It should than bend and appear in the hole. Use the hole and the tweezers to get the cable halfway through.
second try
  • If you are unlucky and loose the cable inside. Try to fix it to a wire.
  • You can also try to use the wire, to block the path through that hole in the wheel, and push just the cable. It should than bend and appear in the hole.
  • Use the hole and the tweezers to get the cable halfway through.
  • Connect the cables. And try the bell.
Insérez ici votre traduction
