Aller au contenu principal
Anglais
Français
Traduction de l’étape 9
Étape 9
Put everything back together. Use some proper electrical tape to get the cable in place. Before you put the tiny 2mm hex screw should, check if hits the flat part of the side of the button. I removed the old glue with the tweezers and  applied some fresh hot glue.
assembly
  • Put everything back together. Use some proper electrical tape to get the cable in place.
  • Before you put the tiny 2mm hex screw should, check if hits the flat part of the side of the button.
  • I removed the old glue with the tweezers and applied some fresh hot glue.
Insérez ici votre traduction
