Aller au contenu principal
Anglais
Français
Traduction de l’étape 8
Étape 8
With those lower components conquered, we have the perfect angle of attack for those stretch-release battery adhesive tabs. Don’t let that “L” deceive you—the Max has the winning battery out of all the iPhones 12, not just in power, but in technology. X-ray vision shows that the Max’s battery pack isn’t quite full to the brim, but it's darn close—and the high-tech shape allows it to turn the corner on capacity. The Max power source weighs in at 14.13 Wh, tipping the scales against the 8.57 Wh mini battery and the 10.78 Wh 12 and 12 Pro.
  • With those lower components conquered, we have the perfect angle of attack for those stretch-release battery adhesive tabs.
  • Don’t let that “L” deceive you—the Max has the winning battery out of all the iPhones 12, not just in power, but in technology. X-ray vision shows that the Max’s battery pack isn’t quite full to the brim, but it's darn close—and the high-tech shape allows it to turn the corner on capacity.
  • The Max power source weighs in at 14.13 Wh, tipping the scales against the 8.57 Wh mini battery and the 10.78 Wh 12 and 12 Pro.
  • This is a slight step down from the 15.04 Wh pack in the iPhone 11 Pro Max, and it definitely falls behind the Galaxy Note 20 and 20 Ultra (16.69 Wh and 17.46 Wh respectively).
Après la conquête de ces composants inférieurs, nous avons l'angle parfait pour attaquer les languettes adhésives étirables de la batterie.
Ne laissez las le "L" vous décevoir ! Le Max a la batterie gagnante parmi les iPhone 12, non seulement en puissance mais aussi en technologie. Les rayons X montrent que le pack énergétique du Max n'est pas plein à craquer, mais presque. De plus, la forme high-tech permet de prendre un virage avantageux sur le plan de la capacité.
Le Max performe à 14,12 Wh, ce qui renverse la mise par rapport aux 8,57 Wh de la batterie du mini et des 10,78 Wh des 12 et 12 Pro.
C'est légèrement moins bien que les 15,04 Wh de l'iPhone 11 Pro Max et on est à des lieues des Galaxy Note 20 et 20 Ultra (respectivement 16,69 et 17,46 Wh).
