Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 10
Étape 10
You can do this step before or after you remove the top. Careful, it is easily broken! (I re-attached mine tastefully with tape, having broken the attachment points. ;o) ) Take a piece of tape, preferably painters tape, and make a small tape T-handle on the rear Jura badge. A small piece of rubber might work or you might be able to get it off with just clean fingers and skin friction.
  • You can do this step before or after you remove the top.
  • Careful, it is easily broken! (I re-attached mine tastefully with tape, having broken the attachment points. ;o) )
  • Take a piece of tape, preferably painters tape, and make a small tape T-handle on the rear Jura badge. A small piece of rubber might work or you might be able to get it off with just clean fingers and skin friction.
  • Carefully push in and twist it to the left ~1/10 of a turn. Then, when you feel that it has come loose, pull it gently out to remove it. It is held in place by little lugs and pressure tangs.
  • After the rear Jura badge has been removed, behind it you will find two T15 Torx screws marked with red circles in the second picture. They must be removed.
  • You can then gently wiggle free the vertical plastic chrome piece that is on the rear - pull out and set that aside.
Insérez ici votre traduction
