Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront le tutoriel qui comprend ces étapes.
Anglais
Français
Traduction de l’étape 8
Étape 8
The right side of bottom case should separate from the top case when you remove the sliding shaft.
  • The right side of bottom case should separate from the top case when you remove the sliding shaft.
  • Do not pull up too far or the wire hinge may be damaged.
  • Slide the top case to the right to separate the joint.
  • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
Insérez ici votre traduction
