Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 6 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 6
Étape 6
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins. You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
  • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
Insérez ici votre traduction
