Aller au contenu principal
Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 2 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 4
Étape 4
With tweezers, gently detach all three ribbons from the motherboard terminal.  Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  • With tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side.
  • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
Insérez ici votre traduction
