Aller au contenu principal
Anglais
Français
Traduction de l’étape 6
Étape 6
Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires. After the wires are removed, disconnect the old switch. After the wires are removed, disconnect the old switch.
  • Use the screwdriver to loosen the 5mm Phillips #1 screws so that you can remove these two traveler wires.
  • After the wires are removed, disconnect the old switch.
Insérez ici votre traduction
