Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Label the black live or load wire which connects to the power or the device and usually on the down position of the switch. Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch. Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
  • Label the black live or load wire which connects to the power or the device and usually on the down position of the switch.
  • Use the screwdriver to loosen the 5mm Phillips #1 screw so that you can remove the live or load wire from the switch.
Insérez ici votre traduction
