Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 1
Étape 1
Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit. Carefully disconnect the fan connector from the socket, as depicted in the second picture.
  • Using a Phillips #2 screwdriver, remove the two screws (circled in red) attaching the fan assembly to the unit.
  • Carefully disconnect the fan connector from the socket, as depicted in the second picture.
  • The controller connector panel can be gently pulled out of the main unit and laid down, as depicted. This is not strictly required, but may provide more maneuverability inside the case.
  • Make sure to not pull out the wires while removing the fan. Doing so may damage the connector wire or the PCB.
Insérez ici votre traduction
