Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 5
Étape 5
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert an opening pick into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Lift the display slightly
  • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
  • Insert an opening pick into the gap.
  • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
Insérez ici votre traduction
