Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Handle the card only by the edges.Do not touch its connectors or any of the components.Lift the card straight out from the connector to remove it, and insert it straight into the connector to install it.Do not rock the card from side to side and don’t force the card into the slot.Once the replacement card is installed, pull on it gently to check.
  • Handle the card only by the edges.Do not touch its connectors or any of the components.Lift the card straight out from the connector to remove it, and insert it straight into the connector to install it.Do not rock the card from side to side and don’t force the card into the slot.Once the replacement card is installed, pull on it gently to check.
  • 1) Release the small locking clip at the front of the card’s logic board connector by pushing the clip up toward the media shelf.
  • 2) Holding the card by the top corners, pull up the card and remove it from its expansion slot.
Insérez ici votre traduction
