Aller au contenu principal
Changement boutons L1 et R1 manette DualSense Sony
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 28 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: étape 0, image 1 de 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: étape 0, image 2 de 3 Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: étape 0, image 3 de 3
  • With one hand, grip the controller and use your thumb to hold down the left trigger.
  • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
  • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
Insérez le côté plat d’une spatule (spudger) dans l’espace au-dessus du bouton L1.
Couvrez le bouton avec votre pouce pour l’empêcher de voler à travers la pièce.
Faites levier vers le haut pour enlever le bouton L1.
[title] Remove the L1 button
-[* black] Insert the flat end of a spudger into the gap above the ***L1*** button.
- [* icon_note] Cover the button with your [link|https://guide-images.cdn.ifixit.com/igi/iA3OsjdvuPLvhmw5.huge|thumb|new_window=true] to prevent it from ejecting across the room.
-[* black] Pry upward to remove the ***L1*** button.
+[* black] With one hand, grip the controller and use your thumb to hold down the left trigger.
+[* black] With your free hand, insert the flat end of a spudger between the ***L1*** and ***L2*** buttons.
+[* black] Use the spudger to gently pry the ***L1*** button away from the controller and remove it, holding your finger over the button so it doesn't eject.
