Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 5 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Flip the Apple TV over so that the bottom of the unit is facing up.
  • Flip the Apple TV over so that the bottom of the unit is facing up.
  • You need to remove the rubber base to get access to the screws.
  • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
  • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
  • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
  • Repeat the procedure described above until the rubber base has been completely removed.
Insérez ici votre traduction
