Aller au contenu principal
Anglais
Français
Traduction de l’étape 2
Étape 2
Measure out a piece of heat shrink to be at least 1/2 inch (12.7mm) longer than the damaged length of the cord. Then cut that piece to size. For a better fit on the cord try to use the smallest size heat shrink possible. Note that you can cut the heat shrink using scissors, a box cutter, or any kind of knife.
Measuring and Cutting
  • Measure out a piece of heat shrink to be at least 1/2 inch (12.7mm) longer than the damaged length of the cord. Then cut that piece to size.
  • For a better fit on the cord try to use the smallest size heat shrink possible.
  • Note that you can cut the heat shrink using scissors, a box cutter, or any kind of knife.
  • Be careful with sharp objects.
Insérez ici votre traduction
