Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage. Insert the battery blocker at a 35 degree angle to disconnect the battery. The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
Disconnect the battery
  • Be extremely slow and careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
  • Insert the battery blocker at a 35 degree angle to disconnect the battery.
  • The playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at a 15 degree angle.
  • Leave the battery blocker in place as you work.
Insérez ici votre traduction
