Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 13
Étape 13
Fragile antenna cables lie under the top edge of the screen. Carefully follow the procedure to avoid damaging them. Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel. Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
  • Fragile antenna cables lie under the top edge of the screen. Carefully follow the procedure to avoid damaging them.
  • Insert the point of a pick under the display where you just stopped cutting. Do not insert the pick deeper than the edge of the bezel.
  • Carefully roll the pick to the right, pressing the long edge of the pick into the screen adhesive underneath the bezel, cutting the adhesive as you go. Do not slide the pick along the edge of the Surface.
  • Repeat this motion of inserting the point of the pick where you just cut, and rolling to the right all along the top edge of the Surface, until the pick is 2.5 inches (64 mm) from the right edge of the Surface.
Insérez ici votre traduction
