Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 17 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 15
Étape 15
Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated. Do not remove the screen yet. It is still connected to the motherboard by two cables.
Open the Surface
  • Very slowly lift the screen assembly away from the Surface case. If you encounter any resistance, stop and check that all the adhesive is separated.
  • Do not remove the screen yet. It is still connected to the motherboard by two cables.
  • Use an opening pick to cut through any remaining adhesive.
  • The flash lens may fall out of the Surface case. Keep track of the lens and return it to its cutout in the case during reassembly.
Insérez ici votre traduction
