Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Anglais
Français
Traduction de l’étape 6
Étape 6
Turn the chair around and locate the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle. Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw. Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw.
Remove Axle Plates
  • Turn the chair around and locate the two base plates that hold the axle to the back of the chair. There are two screws on each of the plates that connect the chair to the axle.
  • Hold the nut with a 10 mm wrench in one hand. In the other hand, use a wrench to remove the screw.
Insérez ici votre traduction
