Traduction de l’étape 4
Étape 4
Remove keyboard 1
Flip the laptop over so that the display hinge is facing you and open the display to a 90 degree angle from the chasis.
Remove the four (4) 7.5mm (BG) screws from the back using a T6 Torx bit. At this point the screen will come free.
Carefully pull up to remove it from its posts and rest backwards, exposing the next screw.
Remove the 6mm (BC) screw from the top right of the chasis using a T6 Torx bit.
[title] Remove keyboard 1 | |
[* icon_caution] Do not try to remove the screw beneath the right screen hinge before removing the display. You will likely strip the head, given the angle. | |
[* black] Flip the laptop over so that the display hinge is facing you and open the display to a 90 degree angle from the chasis. | |
[* icon_caution] Support the display with one hand during the next step. | |
- | [* red] Remove the four (4) 7.5mm screws from the back using a T6 Torx bit. At this point the screen will come free. |
+ | [* red] Remove the four (4) 7.5mm (***BG***) screws from the back using a T6 Torx bit. At this point the screen will come free. |
[* black] Carefully pull up to remove it from its posts and rest backwards, exposing the next screw. | |
- | [* orange] Remove the |
+ | [* orange] Remove the 6mm (***BC***) screw from the top right of the chasis using a T6 Torx bit. |
