Aller au contenu principal
Anglais
Français
Traduction de l’étape 4
Étape 4
Removing The CPU Start by using a flathead to gently pry off the clip, remember you have to put it back on again! Then, remove the heatsink.
  • Removing The CPU
  • Start by using a flathead to gently pry off the clip, remember you have to put it back on again!
  • Then, remove the heatsink.
  • This reveals the Motorola PowerPC G3 CPU, this is the 400Mhz Model.
Quitando la CPU
Comience usando un cabezal plano para extraer suavemente el clip, ¡recuerde que debe volver a ponérselo!
Luego, retire el disipador de calor.
Esto revela la CPU PowerPC G3 de Motorola, este es el modelo de 400 MHz.
