Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Anglais
Français
Traduction de l’étape 13
Étape 13
Removing the power supply Disconnect the power connector from the logic board (this looks alot like a standard ATX connector. The lone difference is that the wire which supplies -5V on an ATX supply [pin 18] becomes a ground wire in the B&W G3.  If you just plug in an ATX supply without any modifications, you'll short out its -5V output. ) There is a 4-Pin Cable connected to the front panel box, remove it.
  • Removing the power supply
  • Disconnect the power connector from the logic board (this looks alot like a standard ATX connector. The lone difference is that the wire which supplies -5V on an ATX supply [pin 18] becomes a ground wire in the B&W G3. If you just plug in an ATX supply without any modifications, you'll short out its -5V output. )
  • There is a 4-Pin Cable connected to the front panel box, remove it.
  • Disconnect the internal fan cable.
  • The Fan Connector
  • Then Route all of the cables up through the case to the level of the power supply.
Extracción de la fuente de alimentación
Desconecte el conector de alimentación de la placa lógica (se parece mucho a un conector ATX estándar. La única diferencia es que el cable que suministra -5V en una fuente ATX [pin 18] se convierte en un cable a tierra en el B&W G3. en una fuente ATX sin ninguna modificación, cortará su salida de -5V.)
Hay un cable de 4 clavijas conectado a la caja del panel frontal, retírelo.
Desconecte el cable del ventilador interno.
El conector del ventilador
Luego pase todos los cables a través de la caja hasta el nivel de la fuente de alimentación.
