Aller au contenu principal
Info : Vous modifiez un tutoriel pré-requis. Toutes les modifications apportées affecteront les tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Place laptop upsid down on a clean flat work surface. Remove the Philips M2.5 x 8 mm screw Loosen the screw that holds the memory compartment closed
  • Place laptop upsid down on a clean flat work surface.
  • Remove the Philips M2.5 x 8 mm screw
  • Loosen the screw that holds the memory compartment closed
  • remove the memory module compartment cover
  • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Insérez ici votre traduction
