Aller au contenu principal
Anglais
Français
Traduction de l’étape 3
Étape 3
Slide each corner of the fan cage off of the rubber grommets attached to the fan. The rubber grommets may be difficult to remove. You have to squeeze the base of the grommet and pull the cage apart at the same time.  The grommets should be pulled apart one at a time.
  • Slide each corner of the fan cage off of the rubber grommets attached to the fan.
  • The rubber grommets may be difficult to remove. You have to squeeze the base of the grommet and pull the cage apart at the same time. The grommets should be pulled apart one at a time.
Insérez ici votre traduction
