Aller au contenu principal
Changement écran MacBook Pro 14" 2021
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Changement boîtier inférieur MacBook Pro 14" 2021
Changement connecteur de batterie MacBook Pro 14" 2021
Changement barre d'antenne MacBook Pro 14" 2021
Informations sur le tutoriel
= Terminé = Incomplet
    Use this guide to replace the screen in your MacBook Pro 14" 2021.
    ***WARNING: While you can physically replace the screen by following this guide, replacement screens are known to display [post|744273|visual artifacts|new_window=true]***. Currently, the only available fix is Apple's System Configuration tool (which is only available through Apple when purchasing a genuine replacement screen). Alternatively, two soldered chips can be transferred between the screen controller boards.
    ***Since macOS Sequoia 15.1, display artifacts will disappear if you update macOS to 15.1 or higher. It is yet to be investigated if non-serialized third-party screens would work as well, but original Apple screens work without any issues. True Tone remains disabled, and there will be an error message regarding the screen in the diagnostics.*** [br]
    ***For your safety, discharge the battery below 25% before disassembling your MacBook.*** This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    ***Note:*** Replacing your screen disables True Tone functionality.
    ''Some photos in this guide are from a different model and may contain slight visual discrepancies, but they won't affect the guide procedure.''
      Étapes du tutoriel
      Étape 1 — Détacher les caches des nappes d'écran
      Utilisez un tournevis Torx T3 pour retirer les quatre vis de 2,1 mm, qui fixent les caches des nappes d'écran.
      Étape 2 — Retirer les caches des nappes d'écran
      Utilisez une pincette, ou vos doigts, pour retirer les deux caches des nappes d'écran de la carte mère.
      Étape 3 — Déconnecter les nappes d'écran
      Utilisez l'extrémité plate d'une spatule (spudger) pour soulever et déconnecter les deux connecteurs à emboîter des nappes d'écran fixés à la carte mère tout à droite.
      Étape 4
      Répétez l'étape précédente pour le connecteur à emboîter tout à gauche.
      Étape 5 — Retirer les supports de nappes d'écran
      Tirez sur la partie arrière du support de nappe d'écran pour défaire les clips qui le maintiennent au châssis.
      Étape 6
      Si les deux amortisseurs de support de nappe d'écran se sont détachés en même temps que les supports, passez cette étape.
      Étape 7 — Détacher le cache du capteur d'angle du capot
      Utilisez un tournevis T3 pour retirer les deux vis de 2,1 mm, qui fixent le cache du capteur d'angle du capot près de la charnière droite.
      Étape 8 — Retirer le cache du capteur d'angle du capot
      Utilisez une pincette ou vos doigts pour retirer le cache du capteur d'angle du capot.
      Étape 9 — Déconnecter la nappe du capteur d'angle du capot
      Utilisez l'extrémité plate d'une spatule pour déconnecter le connecteur à emboîter du capteur d'angle du capot.
      Étape 10 — Détacher les caches des charnières
      Utilisez votre tournevis Torx T5 pour retirer les deux vis de 2,5 mm des caches des charnières (quatre vis au total).
      Étape 11 — Retirer les caches des charnières
      À l'aide d'une pincette, éloignez les caches des charnières horizontalement des charnières, pour les séparer du châssis.
      Étape 12 — Retirer quelques vis des charnières
      Retirez deux vis de 5,2 mm de chaque charnière (quatre vis au total) à l'aide d'un tournevis Torx T8.
      Étape 13 — Protéger le MacBook
      Si vous prévoyez de réutiliser votre écran, ouvrez-le et posez un morceau de ruban adhésif sur la vitre, directement au-dessus de chaque charnière. Cela permet de protéger la vitre contre les rayures lors des trois étapes suivantes.
      Étape 14 — Retirer les vis restantes
      Utilisez un tournevis Torx T8 pour retirer les deux vis de 5,2 mm restantes (une de chaque charnière).
      Étape 15 — Retirer l'écran MacBook Pro 14" 2021
      Tenez fermement l'écran et le reste du MacBook Pro. L'une ou l'autre moitié peut tomber de manière inattendue pendant cette étape.
      Étape 16
      Ôtez l'écran.
      Étape 17
      Lors du remontage, suivez ces instructions pour aligner les charnières de votre écran :
