Info : Vous modifiez actuellement un pré-requis du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 33 tutoriels qui comprennent cette étape.
Traduction de l’étape 1
Étape 1
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
[* icon_note] To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery. |
[* black] Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the [* icon_caution] Do not lift upward on the connector as you disconnect |
