Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 8 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 12
Étape 12
Carefully remove the logic board assembly from the upper case, minding any cables that may get caught. During reassembly:
  • Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
  • During reassembly:
  • Keep loose cables clear of the board so they aren't caught under it.
  • Make sure the antenna cables are inserted into their respective notches, as highlighted in the second picture.
Retirez avec précaution l'ensemble carte mère du boîtier, en tenant compte des câbles pouvant rester accrochés.
Lors du remontage, assurez-vous que les câbles d'antenne sont insérés dans leur encoche respective sur la carte mère, comme indiqué sur la deuxième image.
[* black] Carefully remove the logic board assembly from the upper case, minding any cables that may get caught.
[* icon_reminder] During reassembly, makereassembly:
[* black] Keep loose cables clear of the board so they aren't caught under it.
[* black] Make
sure the antenna cables are inserted into their respective notches on the logic boardnotches, as highlighted in the second picture.
[* black] Make
