Aller au contenu principal
Changement vitre arrière iPhone 14
Anglais
Français
Conditions préalables au tutoriel
Tous les tutoriels prérequis doivent être traduits avant que cette traduction soit considérée comme complète.
Changement vis Pentalobe iPhone 14
Repère de profondeur sur un médiator (prérequis)
Informations sur le tutoriel
= Terminé = Incomplet
    Use this guide to replace a broken rear glass on your iPhone 14. The rear glass includes the charging coil and rear-facing microphone mounted on it.
    This guide was created using the ***A2882*** (international) model. If you're fixing a different iPhone 14 model, there may be some visual discrepancies, but the procedure should be the same.
    ***For your safety, discharge the battery below 25% before disassembling your device.*** This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, [[What to do with a swollen battery|take appropriate precautions|new_window=true]].
    ***Note***: On iOS 18 and newer, you can pair new, genuine rear glass parts using Apple's [link|https://support.apple.com/en-us/120579|Repair Assistant|new_window=true].
    You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
      ***To reassemble your device, follow the above steps in reverse order.***
      After your repair, depending on the replacement part, you may be able to [link|https://support.apple.com/en-us/120579|calibrate it using Apple's Repair Assistant|new_window=true], available as of iOS 18. Update your device, navigate to Settings ***→*** General ***→***About ***→*** Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
      Take your e-waste to an [[E-Waste|R2 or e-Stewards certified recycler|new_window=true]].
      Repair didn’t go as planned? Try some [[Troubleshooting Problems After a Repair|basic troubleshooting]], or ask our [link|https://www.ifixit.com/Answers/Device/iPhone%2014|Answers community] for troubleshooting help.
      Étapes du tutoriel
      Étape 1 — Recouvrir toutes les fissures
      Si la vitre arrière de votre iPhone est fissurée, limitez la casse et évitez de vous blesser pendant la réparation, en recouvrant la vitre avec du ruban adhésif.
      Étape 2 — Instructions Anti-Clamp
      Les trois étapes suivantes montrent comment utiliser l'Anti-Clamp, un outil conçu pour faciliter la procédure d'ouverture. Si vous n'utilisez pas l'Anti-Clamp, sautez ces trois étapes pour une autre méthode.
      Étape 3
      Tirez la poignée bleue vers l'avant pour verrouiller les bras.
      Étape 4
      Placez votre iPhone sur un objet solide, comme un livre à couverture rigide, afin qu'il soit calé à l'horizontale. Ainsi, vous pourrez procéder plus commodément aux étapes suivantes.
      Étape 5 — Chauffer le bord inférieur
      Si vous utilisez une ventouse, suivez les deux étapes suivantes pour détacher la vitre arrière.
      Étape 6 — Insérer un médiator
      Posez une ventouse sur le bord inférieur de la vitre arrière, tout en évitant le bord même de la vitre.
      Étape 7 — Chauffer le bord gauche
      Avec un sèche-cheveux, chauffez le bord gauche de l'iPhone pendant 90 secondes ou jusqu'à ce que la vitre arrière soit légèrement trop chaude au toucher.
      Étape 8 — Couper l'adhésif du bord gauche
      Faites glisser un médiator autour du coin gauche inférieur et le long du côté gauche de l'iPhone, pour couper l'adhésif qui maintient la vitre arrière.
      Étape 9 — Information sur la vitre arrière
      Il y a une nappe fragile le long du bord droit, à côté du bouton d'augmentation du volume. N'insérez pas votre médiator ici, car vous risqueriez d'endommager la nappe.
      Étape 10 — Chauffer le bord droit
      Avec un sèche-cheveux, chauffez le bord droit de l'iPhone (celui avec le bouton de marche) pendant 90 secondes ou jusqu'à ce que la vitre arrière soit légèrement trop chaude au toucher.
      Étape 11 — Couper l'adhésif du bord droit
      Réinsérez votre médiator dans le bord inférieur de l'iPhone et faites-le glisser le long du côté droit, pour continuer à couper l'adhésif.
      Étape 12 — Chauffer le bord supérieur
      Utilisez un sèche-cheveux pour chauffer le bord supérieur de la vitre arrière. Chauffez 90 secondes ou jusqu'à ce que la vitre arrière soit légèrement trop chaude au toucher.
      Étape 13 — Couper l'adhésif du bord supérieur
      Insérez votre médiator sous le bord en haut à droite du téléphone. Faites-le glisser autour du coin en haut à droite et le long du bord supérieur jusqu'au milieu.
      Étape 14
      Insérez votre médiator sous le bord en haut à gauche du téléphone. Faites-le glisser autour du coin en haut à gauche et le long du bord supérieur jusqu'au milieu.
      Étape 15 — Ouvrir l'iPhone
      Enlevez la ventouse de la vitre arrière.
      Étape 16 — Défaire les vis du cache du connecteur de batterie
      Utilisez un tournevis Y000 pour retirer les deux vis de 1,3 mm qui fixent le cache du connecteur de batterie.
      Étape 17 — Retirer le cache du connecteur de batterie
      Saisissez le cache du connecteur avec une pincette et faites-le glisser vers le haut (en direction de l'inscription A15) afin de détacher le crochet supérieur.
      Étape 18 — Déconnecter la batterie
      Utilisez la pointe d'une spatule pour déconnecter la nappe de la batterie en faisant levier et en soulevant le connecteur tout droit hors de sa prise.
      Étape 19 — Défaire la vis du cache du connecteur de la bobine de charge
      Utilisez un tournevis Y000 pour retirer la vis de 1 mm qui maintient le cache du connecteur de la bobine de charge.
      Étape 20 — Retirer le cache du connecteur de la bobine de charge
      Ôtez le cache du connecteur de la bobine de charge à l'aide d'une pincette.
      Étape 21 — Déconnecter la bobine de charge
      Utilisez la pointe d'une spatule pour déconnecter la nappe de la bobine de charge en faisant levier sur le connecteur pour le soulever tout droit hors de sa prise.
      Étape 22 — Retirer l'ensemble de la vitre arrière
      Ôtez l'ensemble de la vitre arrière.
