Aller au contenu principal
Battery Disconnect
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 1
Étape 1
Battery Disconnect, Disconnect the battery: étape 0, image 1 de 3 Battery Disconnect, Disconnect the battery: étape 0, image 2 de 3 Battery Disconnect, Disconnect the battery: étape 0, image 3 de 3
  • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
  • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
  • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
Insérez ici votre traduction
