Aller au contenu principal
Brown & Sharpe 599-571 Calipers Removing Corrosion
Anglais
Français
Traduction de l’étape 6
Étape 6
Brown & Sharpe 599-571 Calipers Removing Corrosion, contact good? skip to step 10: étape 0, image 1 de 3 Brown & Sharpe 599-571 Calipers Removing Corrosion, contact good? skip to step 10: étape 0, image 2 de 3 Brown & Sharpe 599-571 Calipers Removing Corrosion, contact good? skip to step 10: étape 0, image 3 de 3
  • Repair the negative contact
  • Slide the exacto knife (spudger) between the motherboard and the case.
  • Similarly to the daughterboard removal , pry up the motherboard
  • Desolder and remove the vestiges of the negative contact. (In my case it was a cold solder joint and it popped right off.)
Insérez ici votre traduction
