Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 7 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 15
Étape 15
Lift the logic board enough to gain clearance and use a spudger to pry the microphone  up off the upper case. Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Lift the logic board enough to gain clearance and use a spudger to pry the microphone up off the upper case.
  • Slide the logic board away from the port openings and lift the assembly out of the upper case.
  • Before reinstalling the logic board, it is easiest to press the microphone down into its housing in the left speaker to keep it in place.
Insérez ici votre traduction
