Aller au contenu principal
Info : Vous modifiez un tutoriel prérequis. Toutes les modifications apportées affecteront les 4 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 2
Étape 2
Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case. If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive. Remove the microphone from the upper case.
  • Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
  • If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
  • Remove the microphone from the upper case.
Utilisez l'extrémité plate d'un spudger pour décoller le microphone de l'adhésif le fixant sur le côté gauche du boîtier supérieur.
Retirez le microphone du boîtier supérieur.
[* black] Use the flat end of a spudger to pry the microphone off the adhesive securing it to the left side of the upper case.
+ [* black] If needed, apply a little heat from an iOpener or hairdryer to soften the adhesive.
[* black] Remove the microphone from the upper case.
