Aller au contenu principal
Info : Vous modifiez actuellement une condition préalable du tutoriel que vous venez de consulter. Toutes les modifications affecteront les 47 tutoriels qui comprennent cette étape.
Anglais
Français
Traduction de l’étape 3
Étape 3
During reassembly, gently push down the center of the lower case to reattach the two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips. The lower case is connected to the upper case at the center, with two plastic clips.
  • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  • The lower case is connected to the upper case at the center, with two plastic clips.
Le boîtier inférieur est connecté au boîtier supérieur par deux attaches en plastique au milieu.
Lors du remontage, appuyez doucement sur le milieu du boîtier inférieur pour que les deux attaches s'enclenchent à nouveau.
[* icon_note] The lower case is connected to the upper case at the center, with two plastic clips.
[* icon_reminder] During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
[* red] The lower case is connected to the upper case at the center, with two plastic clips.
